Felix's 2015 Yukon SLT Build Thread
felixgun
felixgun
Lafayette, LA
So aggravated. Friend helped me put kit in. Everything works before we put passenger side MAF back on. Once everything is zip tied and Intake reconnected ******* driver side light goes out. FML!!!! Here is a pic of the one side that works and a comparison between halogen driver side and HID passenger side:
---------- Post added at 10:42 AM ---------- Previous post was at 10:42 AM ----------
Not sure if it's ballast or bulb...
tgui
Its the bulb. Mine and my wifes car had the bulb color change before total failure.
Goodinblack
I Like Tacos
Dirty South
This from TRS?
Their stuff has been bad in my experience. Took me ages to get good parts.
Interesting to see the hid flare. This should cause some glare. Not as much as drop in without projectors.... but certainly not hid optimized
felixgun
felixgun
Lafayette, LA
Yep from TRS. The stuff is morimoto though and my last kit was the same and did great...
felixgun
felixgun
Lafayette, LA
Step pad with chrome trim from 15+ Denali's. Looks to be a little under 5" in width. Which is the same as my step pad. So it SHOULD fit. Gonna try and get this done tonight along with the Philips LED reverse lights.
---------- Post added at 07:35 AM ---------- Previous post was at 07:32 AM ----------
felixgun
felixgun
Lafayette, LA
Didn't know that either. I find they're way better quality then DDM and the cheap eBay crap. Guess we will see how they handle this situation. Gotta troubleshoot and see if it's the bulb or ballast before I email em.
felixgun
felixgun
Lafayette, LA
This damn Morimoto kit is pissing me off. If I unhook the relay to the drivers side it works when hitting the unlock button on the key fob but once you turn it on it starts flickering. If I hook up the relay according to the diagram, it doesn't turn on at ALL on the drivers side. I've tested the ballast, bulb, and individual wiring both on passenger side and it ALL WORKS. SO confused. If anyone has any ideas let me know here's some pics of when I got it to work. Reverse lights and chrome trim with new Denali step pad is also on.
Driver side with HD Relay not hooked up (only way to even get it to function, but flickers when car is actually running). Capacitor was hooked up to both sides (which is supposed to prevent flickering so so much for that...
New step pad and chrome trim from '15 Denali's:
New Philips LED reverse lights:
Only time it actually works to show all ballasts and bulbs DO Work. Passenger side is using HD Relay, Driver side isn't... so jacked up:
Video of the flickering once the car is on with it hooked up this way... I hooked it up like it is in the diagram above and the driver side doesn't work at all. Help... someone?!
felixgun
felixgun
Lafayette, LA
Which ground? The capacitor ground or the bulbs ground? They're both on the bad side.
---------- Post added at 10:00 AM ---------- Previous post was at 08:43 AM ----------
Just attempted to put on the OEM center caps with gmc red lettering and they're not flush with the wheel and clips are extremely loose. FML!!!!
You're having a hard time these last two days lol
felixgun
felixgun
Lafayette, LA
The center caps I was pretty much the guinea pig. No one has done OEM center caps on replica ck190. Now we all know it does NOT work lol. I think the morimoto kit I got from TRS has a bad HD relay cable. Hopefully they send a replacement and that's it. Sick of working on it. It should be plug and play.
Conedaddy
