Factory Sub????
G-NOTE
Houston, TX
Does MTX or JL or anybody make pre-fab boxes or pro-forms or anything to replace the factory sub??????
BlizzardX23
Sacramento, California
You going to replace the factory Amp as well? because from what I've heard, the Bose system is not compatible with aftermarket speakers?
NathanJax
Vacation Nathan
Jax, Fl
MTX does...
Model CTYE01BK10-T45
It can come with or without the woofer and with or without a built in amplifier... With the woofer and built in amp it's about $350
gtbigup01
Columbus, GA
What about a 06 Nali?? This sub box states for 01 Tahoes, I'm sure the nali set up is different.
BTW where is the factory sub for my nali?
NathanJax
Vacation Nathan
Jax, Fl
Bottom of the center console toward the front
+1
I've been wondering if I could make that MTX box work in my Escalade. That's why I chimed in on the thread. I was already looking into this.
The problem with Denalis and Escalades is we don't have slots cut out in the plastic that the woofer goes behind...
ecordell
CordellDesigns.com
Merica
Why are the slots a problem? You don't have to have them....
G-NOTE
G-NOTE
Houston, TX
You can always cut a hole where the sub fires and put a sub grill over the hole...
It won't look bad, as long as you find a nice grill cover...
NathanJax
Vacation Nathan
Jax, Fl
Want to stop as much of the rattling as possible
I'm thinking something like that... Cut the entire thing out and make a grill out of speaker grill cloth that closely matches the interior.. hard to find "shale" fabric...
OmarR
Indianapolis, IN
I just ordered a 2002 Tahoe panel (in my color) so the speaker grill would come cut from the factory.
Did 2002 Escalade's have the subwoofer in the rear as well? If so, then the same option should be available to you, unless any 2004 colors don't cross over with 2002.
The only reason they moved the subwoofer on 03+ to the center console was so GM could make it simpler (and probably save $$$) and match it with the introduction of the 2003 Avalanche platform.
---------- Post added at 07:36 PM ---------- Previous post was at 07:25 PM ----------
Nathan, like this one:
Autotrader
Assuming that color is shale, you could even use that VIN to get your part # from the dealer or gmpartsdirect.com
Supreme
MTX does...
Will this work with a 2000 Chevrolet Tahoe?
Supreme
Could someone please let me know will this work with a 2000 Chevrolet Tahoe?
Eagle
Thansk for all the help -STAFF!
EL PASO, TX
if you googled it you would have found the answer was yes.
Ralph Turner
