If you used keys in front for 2 inches ride suffers and really cant do much to make it better especailly at 2 inch level. Spindles ride great since they dont affect the keys or travel
2) what shocks are you using?
3) what rear kit are you using.
4) i need to know your tire size but for example a 3/5 kit on 305 35 24 front is 32.5-32.75 and rear is 32.75-33.[/QUOTE]
I used 2 inch keys in the front and 3 inch lowered springs in the rear. Bought them from MaxTech. Stock shocks. Truck has just less than 70k on it so I figured they might be fine for now. Didn't want to do the spindles until I really thought I want to keep it lowered. I think the ride is "ok" but its the wife's DD and she HATES it. I am going to raise it some and see if the ride is "acceptable". That's why I was looking for the fender height of some stock trucks. What she doesnt understand is the front end was warn, when I started pulling it apart, the front bearings were bad, the bumpstops were cracked in half, one ball joint was questionable and a tie rod was torn. naturally I replaced it all and now it rights very tight, as it should.
I am running the factory Escalade 22's with the factory tires that are 285/45/22. So I am sure that it sits slightly higher than the stock 17's.
so if anyone has their stock height on stock rims or larger rims list them up so I can get a stock height and adjust it some from there.
