Escalade transmission what do I have
#1taho
5150TAHO
niagara falls ont
I have finally had some tine to look over the motor and tranny. so low mileage on both 200km, I drained the tranny fluid, not as nice as I would have liked but the bigger problem the case says 4L60! NOT 4L65.... Is it a 4L65 called a 4L60 HD ?back in 2002 when it came out?
So I went to a caddy web site and it says It is a 4L60E HD. So REALLY what do I have ??????? I really hate to put in the same crap that I have already.
On the 6.0L I drained the oil and a bit of crap was on the drain plug. I am not to concerned but none of my vehicles ever had that. when is too much and Has anyone blew up these motors under NORMAL use?
Just wanted to say how easy it was to pull the motor and tranny complete and I mean complete. I unplugged what was necessary, undone the power steering hoses and out she came. the front clip was off the truck to make it possible to pull both motor and transmission. nothing was cut or hacked.
#1taho
#1taho
5150TAHO
niagara falls ont
Ok I did the research and multiple calls to the dealer. ( tranny guys are Dum BTW)
In 2002 when the ESCALADE and DENALI were redesigned the 6.0L did get the 4L65E. BUT the case stamp says 4L60E.
The code in the glove box should be a M32 for a 4L65E. (m30 is 4L60E) there is a sticker on the tranny that will have this code (2KZD) that confirms it is a 4L65E. now there are a lot of those code but this is the most comon that I was told is used. there are exceptions to the rule but at this time I haven't found any. Hope this helps someone doing this also.
#1taho
#1taho
5150TAHO
niagara falls ont
image.jpg image.jpg image.jpg And as you can see I got the caddy rear glass in the back ground and the corners also. I have some work ahead of me now!!!! I also took the hydro boost for the 2000 white one.
Rdry1952
