Escalade Cluster in NNBS!
Jeffv
I don’t have the part number but the member who sold me the one I used to make my harness told me they’re not available anymore. Maybe you can get one from a wrecking yard or hard wire to the Escalade connector.
Hi so quick question did you have to have the escalade cluster programmed to your vin, i installed mine today all the DIC controls work and all the warning lights work but none of the guages moves and blinkers and stuff dont display on the cluster. Not sure if my wiring is off or if it needs to be programmed. Thanks
67RS427
Wiring is wrong, you should not need to program it at all unless you want the mileage updated...
No, it doesn’t need to be programmed to your VIN so something must be off in your wiring. That sounds like the GMLAN low speed serial data lines which is how the BCM communicates with the cluster. There aren’t wires specific to those functions so the info must come over the local area network (GMLAN). My best guess anyway.
Jeffv
Yep exactly the problem the GMLAN wire thanks
B2sdad
The Hill Country, Texas
I was about to jump on board with this mod on my Suburban since the mileage display died recently...then I read this thread.:confused: I don't have the time to mess with trimming the bezel or pigtails or mileage correction. So i guess at this point I can look into gauge overlays, LED upgrades, new needles? Anyone know someone in Texas that rebuilds NNBS clusters?
Don't know where he lives but this is who I shall use when that day comes:
Jeffv
does the oil life remaining work on your cluster or is it just dashes? i just get dashes for that and the compass zone
I never noticed but mines the same as yours. I don’t use the olm anyway and my compass works fine so the zone must be right.
KidHauler
Mass
So are the pig tail connectors not available anymore? Or would I have to get the clusters connector and make one myself now?
Doug118
The cluster connector was never available. It was the stock Chevy plug end that used to be available but no longer is
KidHauler
Mass
Referring back to the original post from the beginning of this now 26 page thread. He I guess use to make a harness that would connect the 2 but not anymore?
Doug118
What do you guys think would be a good price to sell the whole cluster swap for? Cluster, plug & play harness and bezel. I’m selling my Suburban so I might take the Escalade cluster swap out and just throw the stock one back in
LIT94SS
How much are you asking for it
albac
