Engine temp running 135......under 210 with heater on?
Gossamer
Edmond, Oklahoma
Changed out my thermostat because it was bad. Engine temp was over 235.
Now engine runs at normal temps (just under 210) only if the heater is on. If I turn heater off, the temp goes to about 230-235.
I have tried bleeding the air out several times. Parking on incline with cap off reservoir for several minutes.
Maybe I need to flush radiator?
could be clogged, could be water pump fins worn down to just nub's also, how many miles???
Water pump 1 year old.
Tahoe has 220,000
if that is the original radiator you can put some chemicals in there and run it 2-3 days and flush it out and refill, the chemicals are sold at almost any auto parts store $5-10, that MIGHT help, but my personal recommendation would be to consider replacing it, if you shop around you can a decent replacement for about $180 unless you live in AK or somewhere exotic, rockauto probably has some good prices.
CKendrick
