Engine temp gauge
malones99
My engine temp gauge doesn't work, I will be doing some desert driving this coming week, is there a cheep gauge I can by to get the temp?
malones99
malones99
always cold, I did change the sensor on the top t-stat housing, didn't help
SunlitComet
OBS Jedi-Do Good
unknown at this time.
HA..That was the temp sensor for the computer to use. The one for the instrument cluster is located on the left cylinder head directly between the two front plugs with one wire on it.
---------- Post added at 11:22 PM ---------- Previous post was at 11:21 PM ----------
if it is always cold the wire could be broken or connector corroded out.
malones99
malones99
HAx2! is it the same sensor as the top one?
SunlitComet
OBS Jedi-Do Good
disconnect the sensor and get an ohm reading between the wire and good block ground. Should read 1305 ohms at 100 degrees and decreases with temp increase.
---------- Post added at 11:25 PM ---------- Previous post was at 11:24 PM ----------
Different.
---------- Post added at 11:27 PM ---------- Previous post was at 11:25 PM ----------
malones99
malones99
I was looking at autozone, and they only show one sensor (the top one)... could it be called something else?
malones99
malones99
found it at autozone... they call it a switch! I will check the ohm's in the morning! THANKS FOR ALL YOUR HELP!!!!!!!!!
DallasTahoe
duralast TU230 at auto-zone I think. Vehicle application selection is jamming on me.
I know this is an old post but I was having the same problem, I changed it out and now my check engine light is on, I tried three times to disconnect the battery to clear the codes, each time for about 30 minutes and the sel is still on, is it one of those codes that needs to go through 100 run cycles to clear? Thanks
DallasTahoe
I even plugged in the old one to see if it would change but it didnt
DallasTahoe
Never mind it went away, idk why or how.... Gremlins
Eickybobby5050
