Trippyjoey
So I wasn't happy with the flowmaster it had so I went with true dual glasspacks (had the glasspacks lying around from a gift). The engine wasn't stuttering till right after I got the true duals done. It stutters when cold once it warms up it goes away also a backfire like sounding pop that changes between the left and right side. I've heard many of these trucks require a heated oxygen sensor after such install so tomorrow after work I'm gonna get under the truck again to check if it's a 2/3wire O2 sensor or a single wire sensor before buying one.
Anything else I should look for or check while I'm at it.
I haven't lost a power or any other noises just the engine seems to stutter and I get a pop until it warms up. I really want to get this fixed because I'm planning on installing a wet N2O with a 50hp-75hp shot that I got lying around.
Engine is a 95 350 TBI stock other than the exhaust with 191k miles, automatic 4l60E 4x4. The truck is a GMC Yukon 2 door.
