Hacker-Pschorr
- Joined
- Sep 9, 2012
- Posts
- 23
- Reaction score
- 3
2003 Denali XL
It is 3 degrees with a -16 windchill.
My wife took my truck to work today, on the way home she wasn't getting any heat in the cabin and then the display said: "Engine Coolant Hot" then changed to "Engine Overheating". She immediately pulled over and shut down the engine.
I get there, pop the hood, the coolant level is fine, I don't see any obvious leaks and turning the key to the on position the temp gauge was just under 12 o'clock.
I start the truck, sounds normal. The voltage gauge is off the meter, well past the last number, just stuck there. It wasn't like that the last time I drove it.
I drove home with no warnings, temp gauge perfect and zero heat coming out of any vents.
I'm guessing some sort of heater valve must be stuck closed, how would this cause the engine warnings? My wife pays attention to gauges and said she noticed the voltage gauge and never saw the temp gauge to any higher than maybe a tick above 12 o'clock.
Odd to say the least, any ideas?
