thdrill
In searching for instructions or assistance in the window motor replacement I found minimal information on procedures so:
OK so I was swiping out of the parking deck at work and heard a "pop" in the door and my driver side window slowly eeked down and wouldn't come up. Thinking it might be the motor (cause the window has been slowing down) I went to replace it, unfortunately at 2200 hours at night under flashlight without proper instructions. Well I go the motor attached but noted some fraying of the cable on the actuator, and it seemed the cable had been reversed on the pulley. Anyway I got the motor on and the window slowly went up but with a scratchy/straining sound then it would stop and slowly come down making the same sound. So for now I am stuck with a window that is open approximately 1 inch (better than wide open) and a problem of I still have to get the window working. Probably will attack this again on Wed during the day, but was wondering if anyone had any suggestions or a list of steps so that I may be able to check my procedures and ascertain where I am snagged. Also I have noted that the door light does not come on and the door does not register as "closed"...probably missed a connection (but the door is functional). Once again any help would be appreciated.
Thanks
Paul
Thanks
Paul
