dwmmatt23
i found a guy locally parting out an 06 tahoe and has the efans for $125, what do i need to make sure it comes with or has before i buy to do the swap? what all should i make sure to have before getting them or doing it?
Get the fan assembly, and at least the part of the harness that plugs into the fans.
The rest of the harness you can get from Blackbear? or Nelson performance.
Then you'll need to have your Pins turned on in your PCM to turn/off your fans.
Its not hard at all. I did this on my 04 Z71 as it had a clutch fan also.
125$ is a good price !
how do i "have my pins turned on in my pcm"?
