Dumb question, but....
DenaliAK
Colder than you
Alaska
I can't find this info anywhere.
I need to adjust my headlight beams. The driver's side is aiming high and I keep getting flashed (low beams, no HID's yet, so this is not a good sign...). Plus I can see that it is considerably higher then the passenger side, which is the opposite of how it should look against a wall. How do I adjust them??
I can't find it in my manual and tried a search here with a lot of useless and unrelated results. I'm sure it's simple, I'm just new to the whole Yukon/Denali scene.
brndns_hoe
Plano, TX
pop the hood and look around the headlight, you'll see a couple screws, you need a torx style screwdriver to adjust them
Yuk_Nali_6.0
Should be toward the back of the light and to the outside IIRC.
Jumpshot12
