Dual Alternator wiring 07 Tahoe
MalcDogg
So I purchased the dual alternator bracket and second alternator 4 pin got everything installed but the second alternator is on putting out 11-12 volts and it’s not keeping my second battery charged
Can someone help me out?
exp500
More info needed> Like Exactly how it is wired. How is the computer controlling 2nd alt? There are several threads here with multiple hi amp alts for reference.
MalcDogg
MalcDogg
2nd alternator has a 4 pin
Only 2 wires from the 4 pin one wire with resistor is connected to ignition on
The other wire is connected to battery post on alternator and battery is connected there as while
exp500
Computer controlled OEM Alt in 1st position, 2nd position you have alt idling with no control. You didn't provide what you did for install of 2nd battery, No specs on Truck or alts. Standalone? Parallel? Called charging system for a reason.
I think you bought the wrong alt for your "upgrade", so it has the wrong voltage regulator for way you have it wired.
MalcDogg
MalcDogg
The 2nd alternator (253amp) came with the bracket and 4 pin connector but no instructions on how to wire it the connector only has 2 wires one as a resistor on it I’m pretty sure that wire goes to ignition power when key is on
I have a 2nd battery that stands alone for the second alternator
it’s a stand alone setup
exp500
Post full specs for truck including part numbers for truck alt and#2 alt. 4 pin flat? 4 pin oval? Which 2 pins? or I'm done.
exp500
So your yellow wire has the resistor? Post a link of what you bought. A 1 wire would have been simple. And It looks like you are reading alt voltage not batt voltage.
MalcDogg
MalcDogg
Myles I draw the diagram wrong the first time
MalcDogg
MalcDogg
When I put my voltmeter on the alternator without the battery connected it’s only reading 12 volts or sometime lower not keeping the battery charged
I’m thinking maybe going with a deep cycle instead ‍♂️
exp500
4 pin oval- PLFIS rear view pins- PL stator/light ,I F field/ign, S sense,, tab on top
So yes wired incorrectly. And you have a diode inline, not a resistor in 46-1873 Is it installed Backwards? So were your plans to run alt at full output all the time? Your yellow wire should have Fuse inline. Wrong Harness/connector. But can be made to work. Use 1 wire on "I" For IGN only. P, S ,L unused. Try putting fusible link or fuse in Output somewhere before Battery.
MalcDogg
MalcDogg
Ok so u telling me I have to move the L pin to F?
here’s the diagram
exp500
Only use yellow wire. Sorry for confusion. I was not able to copy print pics.
Not having Your manufacturer of V/R Made it tough. If it is WAI you should be good.
Is Your last pic Post 15 from alt pin positions?(SFLP)Looking at face of connector Front View?
MalcDogg
MalcDogg
I haven’t tried it yet I’m gonna try that when I get home
MalcDogg
MalcDogg
Ok so I wired with just 1 wire and added the fuse before I connected the battery the alt post was reading 12.1v connected the battery and drove around now it’s only reading 11.3v and going down
I want it to hold the battery at at least 13.5 for my sound system
what do I need to do to get this to work
exp500
Have you verified the diode facing correct direction or removed? Voltage at alt Ign plug term when key on. Plugged in and unplugged.
You giving up nearly no info isn't helping- so where oh where is your secret vendor that can't help You?
MalcDogg
MalcDogg
Ok let’s start at the beginning
2008 Chevy Tahoe LS
I have a red top battery that I wanna use for my sound system to power my amps I brought the dual alternator bracket to run 2 alternators
2nd alternator will be stand alone to power the second battery
the 2nd alternator I brought from a vendor who supplied me with the doide and 4 pin connector he told me to wire the doide to ign wire and second wire to alternator post with the battery I did that and it’s wasn’t keeping the battery charged I want the second alternator to at least maintain the battery at 13.5 or more volts to handle the power of the amps
the vendors is no help at all
I’m thinking maybe the 2nd alternator could be bad?
Ur more helpful then they ever been if there is any info u need to help me get this done let me know please
BadDaddy2003
