persistent
- Joined
- Nov 10, 2023
- Posts
- 83
- Reaction score
- 72
after replacing the camshaft and oil pump, i'm getting dtc P06DA, which is an open circuit for the oil pressure control solenoid. since i have the oil pan removed atm, i'm keen to get this dtc resolved prior to closing the oil pan, in case i need access to resolve the matter.
to check the wiring, i have tested for continuity and resistance from the 2 pin plug for the solenoid under the oil pump to the main harness landing at the left side of the engine bay and found that 1 conductor shows 0.0 ohms while the other shows 5.5 ohms. i have also tested all 3 segments of the cable for resistance - (1) oil pump solenoid to right front cover, (2) right front cover to lower left front cover, and (3) lower left front cover to main harness landing - and i have found the only section with a resistance measuring over 0.2 ohms is 1 conductor in section 3, which measures as 5.5 ohms.
to test the wiring, i have followed debug steps i found online. the test results are as follows:
- step 1 - clearing dtc does not work, it immediately reappears
- step 2 - confirmed no short to voltage
- step 3 - disconnected main harness containing the solenoid pins, confirmed no short to ground
- step 4 - i'm a bit confused about exactly what this step is testing, but i think it's testing for continuity/resistance of wiring between the sensor (solenoid) and the control module. this is where i'm getting 1 conductor with resistance of 5.5 ohms, which is greater than the 3 ohm threshold they cite.
is this 5.5 ohm resistance enough to trigger p06da, or is this not the issue?
given that i've narrowed down the high resistance to a particular section of cabling, what are the next steps for testing, e.g. backprobe the relevant pins on each end of the cable to rule out a damaged pin receiver?
