Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
I checked the drl fuse under the hood and it appeared good, there is a drl relay also under the hood, does anyone know how to check the relay to see if its good or not
Yep.....had the same issue when put in LED running bulbs and wanted to see what they looked like. Have a buddy start your hoe outside, put it in gear and hold the brake while you check the DRL's
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
