Driver assist reduced
Mayne
I'm getting a driver assist reduced message park assist and service stabilitrak took it to the dealer and they said gmc warranty it because it was over the 3 year mark. I bought it as a demo with 6200 miles on it. I don't know the in service date on it. I have 32000 Miles on it and I don't know where start to fix this
Tahoe14
Central Fl
Your in-service date is the day you purchased and signed the paperwork. The warranty would start from that date.
dbbd1
Not if they bought it used, then it starts from when it was originally purchased. Unless They bought an extended warranty.
Tahoe14
Central Fl
dbbd1,A demo is not a sold unit. It is usually driven by a manager at the Dealer and is considered a new vehicle until sold at which time the warranty starts.
yukonchief
If you only have 32k miles you still have another 4K to go. 3 year 36k should be bumper to bumper.
Rdr854
Northern VA
Warranty starts on the in service date, which is either the date it was sold to the first retail purchaser or the date it was put into demo service.
yukonchief
So then it’s possible he has even more to go then the original 4K I said earlier correct?
Rdr854
Northern VA
Not likely. I should clarify that if put into demo service, the mileage also counts from that date. The mileage is usually a set amount, with some manufacturers making it the set amount plus the number on the clock when first placed in service.
Also, by demo service, I do not mean a car on the lot that has been test driven or dealer swapped.
M1Gunner
Gainesville, Fl
@Mayne, check for corrosion in the connector behind the driver left foot kick panel and report back with your findings please... check very close for any corrosion aka little green crustys!
EricBeau
