Double Din HU with Bose & Factory Rear DVD
Rigsby94
Wayne, WV
I am planning on buying on a double din headunit for my 04 Tahoe. My Tahoe has the factory 6 disc cd changer, bose, rear dvd, onstar etc. I know I have to buy a convertor to keep all my steering wheel controls, bose and rear dvd. My question is what converter or adapter would I need to buy? I don't want a cheap junk one that is going to mess everything up or not work. And how does the converter wire in and what not? I also will be adding 2 12" subs and amp to this if it matters at all. Any help or suggestions would be greatly appreciated!
magicbus
Wichita Falls, TX
Metra (axxess), and PAC are both manufacturers of excellent products. I've had less trouble with PAC than metra though. Last time I checked, you can only get audio from the factory overhead by hardwiring RCA jacks into the factory wiring at the screen. This may have changed by now since I've been out of the business for five years.
drjay2012
Seattle
check pac audio, they have wire harnesses that are plug n play if you want to stay stock or they have harnesses for dd unit, but requires a little more work
Bentley95
