Door gasket seal thing sagging, how to fix?
mlepage
I have a 2000 Yukon. On the passenger side, both the front and rear door gasket seal things are sagging.
I'm talking about when you open the doors, the rubber along the bottom, it is affixed on both sides but has come loose in the middle, so sags. When you close the door, it sticks out.
See attached images.
Probably this is from being stepped on and pulled over the years. Is this a common problem?
I've inquired how much to fix at a shop, but it's $$$. So my question is, how can I fix this myself? Any suggestions?
Or is there a cheap place I could order a replacement seal that won't cost super $$$ (shipping to Ontario Canada)?
M
mlepage
Yeah but what is that piece? Is it "door weatherstrip"? It's not along the top, it's along the bottom.
---------- Post added at 08:36 PM ---------- Previous post was at 07:43 PM ----------
OK if I look here http://www.lmctruck.com/features/ce/ce9d5.htm it's parts 3 and 6 on the image. But they are $69 each, that's pretty expensive for a piece of rubber. I'd appreciate it if someone could find this part cheaper for me.
ezdaar
Chat Troll
Redneck central, Aka Houston
M
mlepage
I saw that window scraper seal too. I think it's the ones that seal the base of the window, where the window goes into the door. They sort of scrape the window clean to remove moisture as the window retracts.
---------- Post added at 09:50 AM ---------- Previous post was at 09:48 AM ----------
I think I see them here as parts 3 and 6: http://www.lmctruck.com/features/ce/ce9d5.htm
But the price is $69, which will be higher in CAD, then shipping.
I'm thinking if RockAuto has them, it should be more around $29. It's just s single piece of rubber.
M
mlepage
How about just cutting them off and toss in the trash, are they really that important?
I am not sure how important they are. Either they keep stuff from splashing up from the bottom, or they keep stuff from dripping down from the top and following the body, helping to direct them outward onto the running board.
I'm going to try to fix the front one, with super glue and goop.
M
mlepage
I used a thick gel superglue on the front one and it seems to be holding well enough. If not, I'll add more superglue, and goop.
ulakovic22
Argyle, TX
3M Weatherstrip Adhesive if the "superglue and goop" doesn't work. It's what I use when I redo all the seals on older cars.
DCT
Help please. Need part# for this weather-stripping. Thank you.
clandr1
Dallas/Fort Worth, Texas
Based on my quick research, GM 15244250 appears to be the P/N for the front door seals (both driver and passenger), and GM 15244248 appears to be listed as the OEM replacement for the rear driver door seal (it may work for passenger as well, as they don't have anything for the right side listed on GM Parts Direct).
915_Tahoe
Your GM Parts Specialist
HELL PASO, TX
That's seal is not sold separately, it is part of that plastic molded guard. Price on the guard is about 200$, your best bet is a salvage yard. That where I got mine from when mine torn off
DCT
Thanks for the reply. That's not the same seal. The part that's bad is a rubber strip below the door sill. It does not go around the door opening.
DCT
Thanks. Any idea what the part number is?
X-ray Nerd
