Does my 2011 have a PVC valve
TNBob
Not sure what engine you have, but the 5.3s in that era have the PCV valve built into the driver's side valve cover. AFAIK, you have to replace the whole valve cover if it fails. I wouldn't worry about it unless you have a problem (oil consumption, bad performance, etc.)
There was a redesign or two of the Gen IV valve cover to reduce oil consumption. By 2011, I think they had it sorted out.
TNBob
Accidentally posted before finishing. The TSB gives you the scoop on the valve cover/PCV situation. If you have the old design and are experiencing problems, then replace the valve cover. If no problems, I still wouldn't worry about it.
Tupapi
