Does Anyone Have A Suggestion For A Transmission Cooler???
2007YukonXL
I have a 2007 Yukon XL and it has a stock transmission cooler in the radiator right hand tank. I want to add a remote transmission cooler. Any suggestions for a make/model of cooler to add?
I was hoping for a unit made specifically for this SUV but it does not look like there is one.
If all that there is available are the universal fit units, how does one deal with (connect/adapt)the GM Quick Disconnect fittings?
THANKS ALL!!!
Bill
ezdaar
Chat Troll
Redneck central, Aka Houston
This cooler boltS in very easily.
There are two models. The one with the thermal bypass and one with out.
This is the top reccomended trans cooler out of all of them.
Tru-Cool Max LPD47391 47391 Low Pressure Drop Transmission Oil Cooler https://www.amazon.com/dp/B0060NKA1U/ref=cm_sw_r_awd_tgpYvbDRPYTWV
Install thread.
http://www.performancetrucks.net/fo...vw-transmission-cooler-install-thread-470284/
Laser cut mounting brackets. I am unsure off hand if they will work on your 07, do some reading, you will find out.
http://www.performancetrucks.net/fo...nstall-kit-brackets-fittings-hardware-508374/
Candielaine
