Chimes come from radio! (UQA) Left front -AND- Left rear emit turn signal click. (faint in the rear, maybe frequency cutoff?) maybe rear outputs..
When left radio output is disconnected, no signals (assuming chime as well)! Guess I got the 'dumb' amp, yay!
Factory diagram says X2 pin 8 (orange wire) is amplifier control (UQA except Y91) It is not necessary (not fader/balance/vol control..)
Factory diagram says X1 pin 6 (white wire) is entertainment remote enable (U42) It *IS* needed for UQA
Now when I splice right output to both L+R inputs on amp, it does some strange things when adjusting fade/balance.
balance seems to fade, fade affects balance. When one is adjusted all the way, only hear tweeters in front.. WEIRD
perhaps the rear speaker outputs aren't just the rear seat audio (when originally tested, I did not have X1pin6 connected and had no audio whatsoever)
However when everything is centered (fade/balance), the audio sounds normal. (maybe not perfect, hard to tell)
Will do more testing with the rear outputs..
Thanks for the help Doubelieve and me88!
