Differential fluid; use additive or not??
vetterss
Double Oak, TX.
I know this has been discussed and I have read the discussions but I am still not sure. I have a 2009 PPV with the G80 rear end in it and 3.73 gears. GM info lists it as a posi limited slip. So do I add the limited slip additive or not when I change the fluid? The manual calls for 89021677 synthetic which has a newer part number now but does not mention the additive. Can someone please clarify and thanks.
PG01
Up here to the right
Yes, you’re right... different info all over. At some point i read new fluid has additive in it. That said, I wouldn’t add it, drive it around... if you hear any chatter, put some in...
kbuskill
NE. FL.
Just for the record "most" synthetic gear oils have it already in it but adding it to a rear that doesn't require it will not hurt anything.
Escalade2007
