diesel to tbi
Quijibo
I picked up a 94 that was originally diesel. Previous owner had converted to a carb and butchered the wiring and other items. Anyway, I found a 94 TBI motor with low miles, wiring harness, ecu(m), to swap it around...all I need is to figure out the dash wiring harness. It was still original diesel and it's a headache. Anyone have any ideas to get the dash harness right? I've looked in junkyards, Painless doesn't make it for the 94 and I'm fresh out of ideas. :emotions122:
foreverfalcon40
Huh...I only knew that diesel only came with a turbo. If thats the case KEEP THE DIESEL!
clean454
u have a 94 diesel wow u can find a used low mile diesel pretty cheap, i would swap for another diesel y would u want gas!! u can get so much power out of a diesel i want one!!! and u can use any i think 6.5L out of any 94 Chevy, look around for one less headache to, switching would be difficult, gatta switch the fuel tank, lines, and the trannys i believe are different, all sorts of things try and keep it diesel it would be way worth it and those are rare..
vsaravia
