Desperate,need help-Key Fobs suddenly quit working
90PROFX
2011 Tahoe LS:
After a day of normal day of, starting, driving, locking, unlocking etc., etc., I got home parked and locked the car w/RKE. Went out 3 hours later, car wouldn't respond to my RKE Fob, so I went and got the spare, still would not respond to the RKE Fob. Changed batteries in both, still nothing. Can someone please shed some light on my situation as I'm afraid to leave the hose for fear of a total electrical failure on the road.
Thank you in advance...........
PG01
Up here to the right
So, everything has been working fine, no problems up until this point. No cel, dash lights, tire pressure monitors are doing their thing..ie: you can see pressures in the dic display?
Does the truck start and run by just using the key?
You changed batteries but did you clean contacts inside both remotes?
Did you happen to touch the dic switches and accidentally turn something off, there is a setting for rke iirc in dic.
Is there a door partially open or rear hatch or rear window.
Start by opening and closing all doors, hatch and back glass, check contacts in key fob and let us know.
Malik112099
On my Yukon in the dash there is an option to reprogram key fobs. Do you have that option in the Tahoe?
guy from norcal
Check your fuses. If you have power seats check if the driver side still works.
nadthomas
I would start with trying to reprogram them through the DIC. If that doesn't work, you can get replacement fobs of amazon for cheap. I just replacement mine a couple of months ago.
dmad1
2011 Tahoe LS:
My '13 Vette would not start for the wife while at the grocery store. Neither fobs would work so had to jump start it. Ended up a bad battery. Seems the OEM batteries don't hold up very well. 3 yrs with a 3rd party battery without a hiccup since.
gpracer1
Phoenix
20 days old......any update on the fix?
I believe after 2010 you need a tech 2 to program remotes.
varminpoolteam
