Depo projectors
DenaliAK
Colder than you
Alaska
Well, with a little lubriderm on your ping pong balls, you will likely not need pics to witness stiffness..
Sorry, I had to go there-
:lol:
---------- Post added at 06:02 PM ---------- Previous post was at 06:01 PM ----------
I'm getting both headlights assemblies tomorrow, so we'll see what they look like.
Vata, don't want to jack this thread...lemme know what they look like on my thread, please. Now I'm curious.
LordGeek
Ohio
Well .. weather here in Ohio did not let up, it did finally stop raining, however, now its SNOWING :wtf2: well .. thats Cleveland for you !!!
Tomorrow will be warning up, mid 40's and mid 50's by Saturday .. so one of these days, I will get to do the switch on the mounting brackets from the OEM's to the DEPO's.
V
vatahoelt
NoVa
Chrome depos have been ordered and I just picked up my set of BMW projectors. Hopefully I can get everything to work.
LordGeek
Ohio
Ok .. UPDATE .. weather here is good, took a good look at the original OEM headlights and did a comparison with the DEPO Chrome Projectors .. and the answer is .. NO
The mounting on the DEPO's is completely different .. the screw positions and adjusting rods do not match .. I will post photos soon showing the differences between the two.
Overall, that would have been an excellent idea.
CREGAN
Leduc, Alberta, Canada
Here's my take:
If you're the kind of person that is **** about their ride, you'll notice the bouncing. It's not severe, but I am insanely crazy when it comes to stuff like that, so I had to do something. Some folks have said when they put their HID's in, the bouncing went away (theoretically from the wiring and such filling the space), but mine didn't. The issue is that the part where the pin goes in is only attached at the top of the assembly. I took an old spacer from a universal flat panel mount I had laying around and glued in between the back of the headlight bowl and the arm that the pin goes through. That stiffened it up much the way a ping pong ball would.
Honestly, it didn't seem like that big of a deal to fix. That's the only negative I have found to the Depo's.
Hey Mike- I have been reading a lot of your posts about fixing the bouncing in your DEPO's and I was just wondering if you have posted pics of your fix on another thread or if you have any. I am interested in doing a more proper fix like you have done than cramming ping pong balls or foosballs in there. Thanks a lot
Craig
CREGAN
Hey guys- I was just out looking at my Depo's and comparing them to the stock lamps to try and solve the shaking while driving. Is there anyone who has pictures they could post of their fix for this problem so I can attempt it myself? Just not sure where to put something to keep it from rattling. Thanks
Craig
CREGAN
Anybody? Someone must have a picture or the ability to describe the placement for me. I even bought some FoosBalls today!
Craig
YukonXL04
The Riverboat
Arlington, TX
Well I can't help you much because I don't have depos... But my eBay lights shook a little, I put 2 nuts between the light mount and the when the pins slide in and it stopped my wiggle...
Just look at it closely and see where it's coming from
V
vatahoelt
NoVa
if i remember tomorrow, i'll get a pic of what i did to firm up the Depos and stop the bouncing.
CREGAN
Thank you. I would really like to see what you did. For the moment I silicone some ping pong balls in. It looks so bush league but it is working for the moment.
Craig
V
vatahoelt
NoVa
Craig
Off the top of my head, I know I had some metal strapping that I cut a small piece off of and used that as a wedge. But I can't remember without looking at the headlight where i put it.
V
vatahoelt
NoVa
Here was my fix for the depo shake. I took a 1 1/4" piece of this metal banding that I had found and cut a little notch out on the bottom. I then wedged it in between the two places. It's been there for at least 4 yrs with no problems. Only issue might be whether it's pushing the lights a little lower than what they should be. One of these days I wanted to go and make sure my headlights were at the right angle.
CREGAN
Excellent- thanks for the pictures. I bought foos balls and found they were too small (must be Canadian rules Foos Balls) so I got some ping pong balls and they worked. Not ideal but it has definitely helped a lot. It is tolerable now. Thanks again for the pics.
Craig
Drewphil
