Denali headlight swap
dreww2001
STL
I bought one Denali headlight to test to see if it would work and appears like it will fit but I don’t know if anyone has done this and knows any tips on how to do it. It came with an adapter On the light that needs cleaning but I don’t know the purpose of. Any help is appreciated
2AD2354E-9FD4-4636-8E0A-30F6AC4B44E5.jpeg CA6818DD-0AA6-4ECA-9F73-8A6464A9F09C.jpeg
bigdog9191999
sw michigan
it should fit fine, fairly sure they use the same bulb/ sockets so should even plug in. I don't have a standard Yukon, but I have a Tahoe an denali I could compare later.
ta6point6litre
Denali headlights use different bulbs for the low beam. If I remember correctly, they use the same bulb as the high beam, that is what the wiring adapter is for.
yukonfan
i just did this conversion. I have the reg yukon and did the whole front swap without the rad support, but the lights will go right in.
fishcop076
