Denali Gauge Cluster Transferred to Base Model
Justinj360
Senior Member
Hi everyone,
I know someone who recently totaled their 2005 Sierra Denali and he said I could have anything I could salvage from it. The main thing I want is the gauge cluster because it has a transmission temperature gauge. Will the new cluster plug right into mine and will everything be correct like my mileage?
Also, I really don't care for the gray (or tan, whichever it is) color in the denali gauge. Could I swap that part for my black one? I'm talking about the circular extruded shapes around the actual gauges (example in photo).
Thanks for the help.
mattt
If you're interested in selling the grey surround piece, I would be interested in it. Thanks.
Justinj360
Justinj360
Senior Member
no. you'll have to get that reprogrammed
Any idea how much that will cost?
I'll keep you posted on that. I haven't taken these clusters apart before. Will that grey piece come off with the rest of the clear plastic on the front of the cluster?
mattt
Yes, it is one piece with the clear plastic cover.
NathanJax
Vacation Nathan
Jax, Fl
$50-$100
depends on the dealership. I had mine reprogrammed in 10 minutes at the dealer and they charged me for 1/2 hour labor. Others have been charged a full hour labor since that's the minimum some dealers say they'll charge
Justinj360
Justinj360
Senior Member
How hard would it be to transfer the trans temp gauge to mine?
BillBlatt18
Latham, NY
I'd like to add a cluster with trans gauge as well on my 02 suburban^^^
about20ninj45
I have a denali cluster for sale from my denali to escalade swap. Pm me if your interested in it. It's listed in my for sale/ransom listing
Justinj360
Justinj360
Senior Member
Well looks like it's a no go. It was hauled away before I could get to it. I can still find a gauge online and install it right?
BillBlatt18
Latham, NY
I plan on just getting a gauge face, needle and stepper motor for mine. Cheaper and I'd rather not have to go to the dealer
about20ninj45
Are there any good write ups for this?
First put on parking break, then shit gear all the way to first, then remove trim cover. There are 4 12mm screws holding in the cluster in all 4 corners. Remove those and cluster will come out. There is also three plugs to remove from the back of the cluster before it will come out
Justinj360
Justinj360
Senior Member
Thanks but I meant just the one trans temp gauge. Like retrofitting it into my current one
mattt
I don't know about about20ninj45's cluster but the one in my 2004 Tahoe and 2001 Suburban was held in place with 4 screws with a 7mm head. Both of my vehicles also had only 1 plug on the top/back of the cluster. The cluster comes out of the vehicle fairly easily, 10 minutes max.
A good write up for adding trans temp gauge is here...
http://z71tahoe-suburban.com/iboard/index.php?showtopic=19909
Justinj360
Justinj360
Senior Member
That is perfect, thank you.
about20ninj45
Hey man 12 mm, 7mm it all looks the same when your going off of bad memory lol n its 1 plug as he stated
BillBlatt18
Latham, NY
Just picked up a 2500 cluster for my 02 suburban. I'll post up when I do the swap
CrackerJack135
