De-badging the hoe.
mikeykey
I posted this topic on the old forum and decided to re-post it here. I have taken the badges/ trim off one side with pretty unsuccessful results.
I tried to use my fingers and just rub the tape off with failed attempts. Two huge blisters and only one tape strip off with residue still on the paint. I tried goo-gone with some-what results, but not good. Even tried a little mineral spirits without results.
I used a 3m strip-off wheel and it burned the F out of my paint. I watched a whole bunch on videos, read the label and did everything they told me to do. Still a nice burn in my paint! I plan on re-painting soon so I’m not as mad as you’d think one would be after burning my paint.
I’m at wits end with this shit!!! Any help would be appreciated. One side is pretty much done, but small amounts of tape residue still exist.
lowlows18
BrOnX, NY (10457)
i used a power washer to get the sticky shit off on my old honda....it worked pretty good , just be careful cause you can take off the paint if its tooooo strong
puckhead
CO
let the goog gone sit for just a few minutes and just start rubbing. I used some old socks and a non scratch brillo pad. take alot of elbow grease but it will work out. then use some scratch out or whatever its called and it should be good to go. dont forget to wash and wax soon after.
Lifted99Yukon
Kansas City, Missouri
I used the 3M Rubber Wheel on mine. Always works out the best. If you burnt your paint, probally held it on there to long.
I actually sold the exact 3M wheel to Denaliano on gmfullsize.
Before:
Sides Done:
tast101
Colton, CA
I just did mine. Used goo gone and some alcohol and a microfiber towel. I scratched my paint using a old credit card on my first one, so after that I put painters tape around the emblem before I started the other ones. There's still a little outline, so I'll get on it with the polish and the PC, plus I have to get out the scratches I made anyway.
haks310
Got LEDs?
SoCal
Wow, that blows, sorry. I used a heat gun and the 3M stripe off wheel on mine and it was done within 2 hours. I would try using the 3M adhesive remover, spaz, posted earlier.
Where are you located? I wouldn't mind helping you out.
M
mikeykey
This is great information.
I thought I was holding the strip-off wheel on too long until I tested it by being very careful. It didn't matter if i hit it for a second or 3, still burned it.
I'm going to try some of the solutions suggested and get back with you.
The hoes at the tint shop getting some new, darker tint on her. All the work is getting me closer and closer to all black!!!!!. I need some black rims now. Whatcha think of these?
http://www.procomptires.com/truck-jeep-wheels/pxa-series-7005-wheels.aspx
M
mikeykey
Im in FL Haks. I think im going to try to use the adhesive remover from 3m. I'd like to find it locally instead of ordering it though.
Lifted99Yukon
What type of drill were you using?
haks310
Got LEDs?
SoCal
Those would look really nice if they didn't have all those rivets around it.
Wow, what kind of drill were you using? Must have been some serious RPMs.
Damn, that would be quite a ride wouldn't it.
Local auto supply store should carry it, if not a local automotive paint shop. I would try the latter first though.
M
mikeykey
Yeah, I like the style but not the silver rivets either. It reminds me a little of a stock chevy rim. I'll find the style.
I used something similar to this
96ProCompTahoe
IN
i let mine sit in the hot sun and rolled the tape off with my thumb (two nice blisters) but it got the job done. took about an hour for the whole process.
I've used the wheel but couldn't find it at the time. (worked well on a different vehicle)
wasn't impressed with the 3M stripper.
VA
I used a hair dryer to heat up the glue, put some goo-gone on it and let it sit for a couple minutes, then scratched residue off with my finger nail. washed and wax area twice looks like the emblem were never there.
haks310
Got LEDs?
SoCal
You did not go over the recommended RPMs, correct? It is 2500RPMs max or something like that.
M
mikeykey
Mine is only 1500 rpms.......Im at a loss of words then. Everyone else has had luck except me....figures.
haks310
Got LEDs?
SoCal
Damn only thing would be you putting too much pressure but I doubt that. You just need to barely touch the adhesive wit the wheel and it will come right off.
Brace
