DD nav in non-dd truck
titanium02
w7's or bust.
Norfolk, VA / ATL
Tag.
JK I'm comin to TX in the spring.. I'll drop the yukon off and you can take care of the HVAC LED's and the Double Din :)
coopiesb
wichita falls, tx
elicpse double din just used the install kit
JKmotorsports
JKmotorsports
Austin, TX
Coopies is at least an 03 or newer model that has the corporate dd hu. You can tell by the hvac controls in his pic.
JKmotorsports
JKmotorsports
Austin, TX
So for those who don't know, the 03+ models already utilize a dd unit, so all you need is the avg $20 dash kit. But unfortunately, to integrate with the databus controlled hu, you're also going to need the more expensive wire harness/module.
Sam Hamm
the picture where you built the bottom screen for the 04 with a dvd player. did you use mdf or what to build the trim around the tv? and old same with the cupholders/dvd player.
and also what did you cover or paint it with.
JKmotorsports
JKmotorsports
Austin, TX
I used MDF and fiberglass.
Kyle C.
So did you utalize dash kits from pre 03 and 03+ to get the flush finnish? I'm thinking of tackling the same job myself, I usually wouldnt even think of cutting or trimming the dash but you made it look pretty easy. I just want to make sure I can get the nice finnish look.
JKmotorsports
JKmotorsports
Austin, TX
I used the brackets from the older pre-03 kit and cut the rest of the trim pieces myself.
BOTTOMLINETRACKS
i would like someone to put a dd din in my white 2001 tahoe with full console. I live in ny..long island.
BigDawg99
NB Canada
i went to my local walmart Today and all they had was Scosche products...You wouldnt know the part numbers that i need for my 02 Yukon Denali..I dont really Care about the Chime and the Onstar...just want to get a DD installed on my Truck...
gdddup
NJ
just finished my double din install in my 2000. this how to was so helpful. props to JKmotorsports
04ctd
Charleston SC
http://avic411.com/index.php?/topic/26611-d3-in-an-01-tahoe/page__gopid__227716#entry227716
JK, why are you using a D3?
I have one, and have learned it's quirks, but it's not really great at anything, but it is "good" at a few things
since they are aging, and becoming cheaper used, i was gonna get another just to prevent having to learn the quirks of another Navi system.
do you think I can use your method to put a DD in here:
it's a 2000 tahoe OBS
mtyler7807
Richmond VA
I did this about a year ago. PM me if you need more info.
varminpoolteam
