Dash squeak driving me insane
DominatorC
Hi I am new, I own a 2017 Tahoe Premier. I have a extremely annoying dash squeak noise that occurs at any speed intermittently. I removed different parts of the dash to no prevail, I can not pinpoint where its coming from. I'm just curious if anyone had anything similar.
GMT800 2005 Tahoe Z71
Navy Supporting Member
Welcome to the forum.
PITA squeaks. I had a 1988 Z71 pickup with a dash squeak. Caused me to get rid of it.
D
DominatorC
Does anyone at least have instructions on how to further disassemble the dash around where the airbag is?
Welcome to the Forum from NH.
Pics of the truck, please.
I cannot personally help you with your question; however, other members on this Forum that are much more knowledgeable than me will chime in.
D
DominatorC
Ironically I took it to my mechanic friend to look at (which has a bumpy driveway) although the whole drive over it did it, it stopped doing it since arrival there. Couldn't replicate for him and couldn't replicate on the way back.
Matthew Jeschke
Sahuarita, Arizona
I have a 2001... May not translate... I rebuilt my dash, mostly. Have to tear it down again though similar problem but only when off-road.
Dash is overwhelming, but when you break it down not too bad. Snds like your friend knows well enough to help.
Basic structure / disassembly... You have a skin which lays on a skeleton. There are technical words for it but I forgot them. Pull the lower knee bolsters off. Then the top, and then remove the controls. You may also have to remove A pillar trim.
This exposes the skeleton everything attaches too. You will have vents and various control boxes on top of Skelton. You can remove all those.
You also have to remove the steering wheel. Then the skeleton can come off. This exposes an inner aluminum structure holding steering column, wiring harness etc. On passenger side and center is the air handler for HVAC.
That is as far as I have gone... Hopefully you don't need to do all that. Somebody smarter than I probably knows how to remove it all at once cause the factory installs dash assembled from what I understand.
Long story short... Get yourself felt tape, gorilla tape, foam tape etc... Insulate and take things off that might be source of rattling WHENEVER you take it apart. Also make sure your screws and fasteners are all snug... Don't crank of them but say zero lash and tad more. You can also put small bead of rtv on parts that might cause a rattle or squeak. Apply very small bead, and let it dry before reassembly.
My two cents. Oh one last tip, if every you need to learn, visit local junkyard and disassemble one of the wrecked trucks
nglauer
My 2015 squeaks, but mine appears to come from the driver's side of the center console near my knee. If I press on it, it'll stop. It's rather annoying but I haven't had a chance to fully investigate it. I also get a squeal from the rear HVAC on occasion as well as my front blower as well, but only when on lowest speed and not constantly.
ivin74
05 NBS Nali
Htown, Texas
Like others had said as you put the dash together put felt on the surfaces that you think are rubbing. I recommend the moleskin (link below) because the adhesive is the best I have found. I keep this stuff in my tool box all the time. Every time I remove panels I install back with some felt.
AdrienR
