DADS 95 Silverado to 2010 update
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
well few things have gone on since last posting on this truck. Ended up c notching it with a belltech notch
Well going to start working again on the truck. Front tires are toast and they were a little wide so i opted to go with a 255 50 20 tire and keep the same tire in rear 295 45 20 and truck has settled so the rear sits a little lower than the front................... but not for long I have 2 inch hotchkis springs i will be doing a belltech 1 inch spacer on them so ill see how the 3 inch drop looks in front.
Front suspension ill start checking tomorrow the truck sits in the garage so I know wont be to bad rotted out but ill prob replace the upper/lower a arm bushings but fore sure ball joints.
Nice looking truck! In 92 my dad special ordered an extended cab sierra with a 350, 5 speed and 3.73 gears. AWESOME truck! I learned how to drive a 5 speed in it. Wish he'd never sold it and so does he :okay2:
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
notched it
so got the new front tires on. Here is the pre pic as you can see the rear has come down over the past 2 years
i then was like **** it so i pulled off the rear chevy tag ill clean it up over the weekend
So came home my dads like "i want you do clean that **** off" so weekend ill have to buff the tailgate out. We then were looking at it and the Truck needs to be lowered in front. Currently on 255 50 20/295 45 20 front is at 30 1/8 and rear is at 30.5 on pass side and 30.25 drivers (full tank of gas) so ill be doing the springs this weekend should look stuffed in front. I have the belltech camber kit im putting in also in rear shock extenders belltech.
I then told him lets do a rollpan he didn't want to but then i told him **** it ill but it hes like ok lets do it lol so ordered goodmark rollpan from summit
Just some updates
Then rear taillights look like they need work so looking to get a new OEM batch since the led stuff is way to flashy
and picked up a new front polished bowtie since the chrome one is pitted
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
cali lean is gone!!!!!!!!!!!!!!
Ended up lowering the front got 7/8 out of it My pops asked if we could stuff fatter tires in the rear. I will be adding 2 inch shackles to the back and adding 305 50 20 (have 295 45 20 on it now) Should look stuffed in the rear
Before
After
ROLL PAN ON
before
after
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
been a while since i updated this
305 50 20 are in the rear now and i lowered it more both front/rear
Changed his oil today and going to do the rear end fluid and bearings. Truck still looks clean.
Man those are some wide meats in the back!! :rocking:
350ss
It's been a while since you probably looked at this but i'm going for the exact same look on my 99 2wd 4dr tahoe and that tire / wheel combination looks great.
skimmed through your threads here and over on tbssowners and think i got it right:
front 255/50/20 on 20x8.5 +14mm offset
rear 305/50/20 on 20x10 ? offset
is the front offset correct and do you know the rear offset number?
any rubbing on the rear and did you have to trim the fender lip?
dads truck is perfect, thanks for documenting it :)
350ss
thanks, will be hitting you up for some parts in the future hopefully... appreciate all the help you provide on the forums
