Txfiredude
- Joined
- May 4, 2025
- Posts
- 8
- Reaction score
- 2
Hello all, I am at my wits end trying to figure this out. Hopefully one of you has had a similar problem that you have solved. Engine on my wifes 2010 Chevy Tahoe 5.3 is throwing a p0301 code. Replaced spark plug, spark plug wires, coil pack, and injector. It has 250k ish miles and each cylinder is showing roughly 100 psi of compression including the trouble cylinder. Fuel pressure is reading 60 psi. Confirmed that the spark plug is firing by putting an old one and new one on the spark plug wire while the car is running and observing good spark. Pulled the lifter cover and the lifter isn't jammed or bad. It lifts just like all the other cylinders. I know its cylinder 1 due to disconnecting the spark plug wire while its running and it does not change the rough idle. Pulling other wires obviously makes the idle worse. Only things I can think of left are the crankshaft positioning sensor and the PCM. It also throws a stabilitrack and traction control error with the p0301 code so I'm not sure if that's the problem. Any input appreciated, thanks!
