CV Axle nut...what size is it?
Mr T
Folks:
Doing a left front Hub replacement. Want to make sure I have the right size long socket for the hub nut for the cv joint. I drive an ‘08 Yukon Denali; I’m sure all are the same, but just in case. I’ve ordered ACDelco replacement HUB and knockoff axle since I’ve heard the hub should be OEM—if possible—but the axle isn’t as critical in terms of OEM quality.
Thanks!
TKH
St. Louis
I believe it's 35mm. I'd have to check out in the garage to make sure, but it's either 35mm or 36mm
2001 Yukon SLT
2012 Yukon Denali XL
2011 Yukon Denali RIP 5/20/18
M
Mr T
Glad I asked because I don’t have a 35 or 36mm deep socket on hand. Thx.
St. Louis
Yup, just checked and it's 36mm
Also have a good/long torque wrench when you tighten it. Torque spec is like 177 ft lbs
2001 Yukon SLT
My original nuts were 35mm and the Dorman replacement is 36mm. They are not to be re used. The bolts on the back can be reused and go to 133 ft lbs. Stop by and borrow mine, no use buying them when you'll only need them every 100K miles! ;)
HiHoeSilver
Away!
Chicago
X2. I ended up with both sockets. Lol
St. Louis
When I first changed the hub on my 2001 I used the 36mm socket and it worked fine to remove the factory nut. Not sure if the nut I installed was 35 or 36, but the 36mm socket worked fine on that also.
2001 Yukon SLT
Wolfbraid
Winston Salem, NC
You'll need a good long breaker bar to break the old ones loose, driver side was easy for me.. pass side I had to stand on my "extension" until it came free.
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
Luckily it's the same as my '89 GMT400 K1500 was and I saved the socket so it worked fine on my '07 Hoe after I dug it out of the bottom of the socket drawer in the tool box. :)
St. Louis
Unless you have air tools and a good impact gun ;)
2001 Yukon SLT
M
Mr T
Indeed it was 36mm. I did the replacement today. All went well and the noise is gone. However, I have a question for those of you who have done a hub job. I read the torque specs are 177 Ft/lb of torque on the axle nut. My torque wrench, unfortunately, only goes to 155. So I torqued it to 155 and then put by breaker bar on to the socket and move it a slight bit more. So I'm tighter than 155, to 177? Probably, if not further. Is there a risk going too tight with this? I don't really want to go buy a torque wrench that goes to 177 but knowing I might have over tightened it with a breaker bar worries me. Not sure what could go wrong. I didn't go crazy, just gave it a little pull from the breaker.
Also, those hub nuts (3) that hold the assembly to the knuckle are supposed to be torqued to 133. Holy cow that's hard in such a small space to get them that tight. I ended up putting a open-end wrench on each and hitting the wrench with my rubber mallet multiple times till it didn't give. The bolts are only a 15 and rathe soft. I need to get back under there and torque them properly but my current torque wrench is a bit too long to make this work. Need to buy a smaller one.
HiHoeSilver
Away!
Chicago
You're good at 155 + a yank. 133 is nuts on those 3 15mm, imo. Just get em good and tight. Check on them in a while if you need to ease your mind.
JamesLond
Sorry for the update mods.
I just wanted to say that for my 2001 Yukon, the nut is 35mm. It seems that if you're using an aftermarket axle, it will come with a 36mm nut.
A 36mm socket will probably work, but I don't like living that wild.
Yes, I have removed 35mm nuts with a 36mm socket before.
MonteJ
