Alright, so i'll start a thread and see if we find the problem or not. I know the go to response here is "check the grounds" great, will do, let's move on from there because that's not the issue. Did some searching, and i can find a lot of other threads about this on various forums, but every one i found, the thread dies without anyone reporting a fix, just others tagging on asking if they find the issue. So maybe this one will end up like that, maybe it won't, let's find out together.
The ride, 2015 Suburban LTZ, fully loaded, approx 170kish miles
The Issue.
Yesterday, after leaving the ranch, i had come to a stop at a stop sign. After coming to a complete stop, i started going forward, made it about 25-30 degrees and the entire electrical system started shutting down like a bad connection. The truck didn't completely die, but it was trying. I had some throttle input as i was turning into traffic, so everything sputtered, and then came back to life. Burb wanted to act like nothing had happened. Made a left after that, no issues, couple stops from stop lights life was great. Made a right into a parking lot, and again, around 30-45 degrees, she cut out. This time, i didn't have much if any throttle input as i was turning into a parking lot off the road. But lost all power. Completely died. Coasted into a parking spot, and restarted like nothing had happened. By the time i had coasted into the parking spot, the electrical system had started coming back on, but i had nothing for a full second or two. After the restart, we went to where we were going. Came back out, and were on our way home. In the parking lot in park i turned the steering wheel lock to lock several times, then i put it in drive, did the same, no issues. Attempted to force a repeat of the failure in the parking lot, sharp right turns at low speed, couldn't get it to replicate. On the way home we had 1 sweeping right turn, and 3 sharp right turns at low speed. Not a single issue. every turn, right or left i tried to replicate what had happened earlier in the day, and no issues. burb wanted to ignore the issue.
Wife and i joked about it being because we had talked about selling the burb, so it is kind of superfluous for us. Her Acadia can do almost all the SUV stuff the burb can do. My truck does all the towing and misc stuff a truck should do. We were discussing getting something else as a spare vehicle that might serve a different purpose, and not be a duplicate of an existing vehicle in the fleet. So maybe the burb is mad, but in the several years we've owned it, this is the first time it's acted up like this, so i'm kinda curious
What i've found people suggest the most, Check grounds, battery connections, Alternator, and i saw some mentions of a Electronic power steering module. However the service bulletin i read on it states a loss of power steering, not a complete loss of power throughout the entire vehicle, including shutting down the engine. That makes me lean more towards battery connections, battery itself, which i'm pretty sure is pretty new IIRC, but i honestly forget off hand. Alternator makes sense, but at the same time doesn't due to the complete failure and intermittency, as well as grounds fall into this due to the intermittent nature. In my experience, bad grounds causing issues can be repeated pretty easily, same with alternator. This almost acted more like maybe computer or solder failures.....idk. Curious what y'all have heard or seen. Also curious if it'll be a couple of months thing, or what. Probably going to send the truck back in for service since i think i got all my truck stuff done so need the repair shop to fix a couple of things i don't think they did right under warranty repairs, so the burb will go back to being a DD during that time So i will likely find out how intermittent this issue is....
The Issue.
