Crash safety : 2007 to 2014 Yukon Vs 2015+ Yukon
Alan2017
Beirut , Lebanon
I do own both 2013 Escalade EXT & 2011 Yukon Denali. Lately I been viewing some crash test videos of this generation of GM SUVs compared to newer 2015+ models I was shocked that the 2015s are alot safer. I appreciate all views
Alan
Why shocked? Shouldn't consumers expect that automobile manufacturer's will endeavor to make their products safer?
What is not measured or reported are the vehicles least involved in crashes, those with superior situational awareness and the ability to get their driver's out of harm's way.
Mine own proclivity is to not go out and buy the next generation because it is rated as superior in an accident.
GTNator
Senior Member
You should check out the crash tests on the Expedition. That’s impressive. Something for GM to strive for.
tsuintx
DFW
Shocked? Why?
NNBS design was probably started around 2004-05 and no major changes were instituted during the production run. The K2xx design was probably started in 2012-2013. Pretty sure safety design took quite a big natural steps forward during those 7-8 years. Just like any other technology.
GTNator
Senior Member
I still don’t understand why they don’t do the offset frontal crash test on the Suburban. I think Chevy needs to submit a vehicle to get them to do it but I would really like to see the results. This is an important test.
Well, as for me and my house, we do not buy vehicles based on ratings, especially from the grossly biased and discredited Consumer Reports.
You could however conduct your own test...
GTNator
Senior Member
I’m not sure why you mentioned Consumer Reports. IIHS and NHTSA do the crash tests. And the GM trucks do not perform as well as the Ford Expedition.
The other point I was making is that I would really like to see IIHS Test the Suburban with the offset frontal collision. However GM needs to submit a vehicle to them in order for them to conduct this test. It’s a really hard test to pass. I saw a Ford F-150 fail miserably, the entire drivers cabin collapsed. This was a few years back, then Ford improved their design and now they perform much better.
HotCarl
ID/WA
2015 Frontal Crash Test
2013 Frontal Crash Test
GTNator, I agree. Overlap tests on the suburban would be nice to see. A lot of full size trucks, particularly crew cabs do poorly in that test.
A
Alan2017
Beirut , Lebanon
So technically my 2013 Escalade EXT being a crewcab will be less safe than my 2011 Yukon Denali ?
I just also seen the 2012 Suburban side crash test ( moving deformable barrier ) it's v scary the suburban rolled over from the impact! This is YouTube video link
HotCarl
ID/WA
Not really the point I was making. As I couldn’t find an overlap crash for a Suburban I don’t know if it is safer than a crew cab truck of the same platform. They may be similar actually.
The point I was getting at is that in the overlap crash, extended cabs usually do better than crew cabs.
So perhaps the suburban/tahoe would perform similarly to their crew cab truck counterpart?
Watch this video, specifically the Silverado tests. Crew cab performs worse than the extended cab.
A
Alan2017
Beirut , Lebanon
Thanks Carl for info that's v scary crash test on Silverado and Ram crewcab. So my 2013 Escalade EXT can be as bad as Silverado or Ram crewcab ?
HotCarl
ID/WA
Don't know. I would suspect the Escalade EXT/Avalance to perform closer to the Suburban/Yukon than Silverado. No overlap test videos are out there on youtube for the burb/hoe/kon/Esky...
But I did find this, which is essentially your Esky EXT.
A
Alan2017
Beirut , Lebanon
That's Not bad at all it looks passenger compartment stayed intact. If am Not mistaken they got 5 stars rating for frontal crash ?
Hodmjstone
