Cost/Benefit - Whipple or TSP Cam
Drob78
Looking for insight as I weight the option of either a Whipple or Cam on my 2019 6.2RST.
Whipple is ~$6500, maybe a bit more/less depending on where it’s purchased. Seems 150rwhp gains are experienced, and I could tackle the installation.
CAM would be ~ $1200-$1400 with phaser and DOD delete (estimation) however this install is above my skill set. Professional install would be..., another $1200?? And performance impact, I haven’t been able to find a dyno comparison, is it 20-30rwhp or 50-60?
Appreciate anyone’s experience, suggestions and guidance on the matter.
Thanks
sealandsky
Minneapolis, MN
Thanks
You have the only other Tahoe / Yukon with the same wheels as mine that I've come across! I'm driving a Callaway Yukon Denali and find the 120 HP gain to be adequate, less power = not good in my mind. I'd do the Whipple, but if warranty is important then bring your RST to Callaway for the conversion.
hcvone
Huntingdon Valley, PA - Town of Webb, NY
I have supercharged and twin turbo charged cars and an SUV before, the problem is resale, no one wants it when you try to sell it, so you spend the money and turn it back to stock to resell it, I tried something different this time, ordered my truck and had it shipped to Callaway, and I am just so pleased, and with the 5 year 60k warranty from Callaway and GM the next owner will have nothing to worry about
91RS
GA
You won't get the most power from a cam unless you do long tube headers also to let it breathe. The same applies to the supercharger (you probably won't get a 150hp gain without headers) but if you don't want to do headers, the supercharger will get you much more power than the cam. I also wouldn't recommend deleting the VVT on a truck, it REALLY helps them get out of the hole. Regardless, if you have the money the supercharger is going to be best for power with great drivability whether you do headers or not.
Install the cam yourself and it won’t cost much. New cam and dual valve springs for less than $500. It can be done through the front without removing the heads. I did mine in my 02 in a day and I’ve never done it before. Every shop wanted to do it from the top which meant pulling the Whipple and heads.
91RS
GA
Yeah, because that's the right way to do it. Who replaces a cam and doesn't replace the lifters? Besides the fact that these trucks have horrible lifter problems and the AFM needs to be deleted which also requires lifter replacement. Hardened pushrods are needed and a trunnion upgrade on the rocker arms is highly recommended. It will cost more like $1500 in parts to do it right.
MCDizz
