Converting 6lug to 8lug IFS - Tahoe
sparg93
Expedition Tahoe
NJ
Anyone with experience converting 6lug to 8lug while retaining the IFS?
If so, are you aware of any writeups or have a few minutes to discuss this with me?
yates ™
Resident Apple hater
Iowa
Not trying to be negative but what would be the point of this :shrug:
S
sparg93
Expedition Tahoe
NJ
Good question!!
A SFA (solid front axle) swap is about $10k for the quality of parts/work that I'm looking for. With that price tag, it's hard for me to justify that kind of money for an expedition rig that is NOT a rock crawler.
However, I would like the added piece of mind and strength of a 14bff in the rear and I personally would love an 8lug Tahoe b/c it stands out as somewhat unique. There is a 6lug 14b, but I've been told it's not as strong...but def an improvement to our 10bolt rears.
So...if its easy to convert 6 to 8 retainig the IFS, I may go that route. I know swapping the 1/2t IFS to 3/4t IFS is very difficult (after weaks of research, couldn't find one that completed it), so I'm wondering if just swapping for the lug pattern is possible.
However, I just spoke to my local 4x4 shop and I'm soooo tempted to complete the SAS.
yates ™
Iowa
So you are upgrading the rear end which will have an 8 lug pattern and want to update front to 8 lug but not SAS?
preshus
washington,IN
i'v ben wanting to do that also but its pricey right now for me . . . you buy its like wheel
spacers i think is what there called they convert just about any lug pattern and space
the wheel out you can get them different widths but from what i understood about it
thats what it dose . . . depending on what brand you want the price go from 50 to
couple hundred
---------- Post added at 12:05 PM ---------- Previous post was at 11:59 AM ----------
im sorry not wheel spacers . . . wheel ADAPTERS lol i'v ben wanting spacers to so im still
stuck on that word
S
sparg93
Expedition Tahoe
NJ
correct, 8 lug front IFS, not a solid axle.
Preshus - wheel spacers/adapters are heavily frowned upon b/c of their failure rate...I personally would never run with them on my rig. However, I don't have any experience with them, but I think a few guys on here could comment with actual knowledge (mine is purely academic)
yates ™
Iowa
That makes sense then. When I first read it I thought you just wanted to switch to 8 lug just for the look.
S
sparg93
Expedition Tahoe
NJ
nope, I also want a locker so I need a stronger rear....plus with my spare tire, I need it to be able to fit on either axle. :)
steamroller
The South
I've not personally done it but the 6 lug unit bearing hubs that we have fit the 94-98 8 lug Dodge solid axles. Search for threads by Norcal4x4 on FSC and lumpdog on Pirate4x4 to confirm.
I know that's the opposite of what you want but that would mean the 8 lug Dodge hubs should work with the 1/2 ton IFS. Only issue I see is that on the Dodge axles the hubs are threaded and on ours the knuckles are threaded to hold them in.
If you're not gonna be abusing it a 6 lug 9.5" SF 14 bolt would be fine IMO, bolt right in and has several traction aids available.
Or convert the FF to 6 lug and disc brakes at the same time.
http://shop.virginia4x4.com/Bolt-on...rsion-Kit-14-bolt-6-lug-VA4X4-BR-BO-14B6L.htm
purple 'hoe
Green Bay, Wisconsin
You can do a good Solid Axle swap for way less than $10k. If you can weld/fabricate, you can do most of it yourself. Shackles are cheap. Use 52inch springs for the front (can be found on OOBS Chevy trucks). Just add in your shocks, and steering components. You can always add things in later (Hydroassist and such) if you need it.
http://pirate4x4.com/forum/showthread.php?t=788003
http://www.pirate4x4.com/forum/showthread.php?t=1032349
Perfect examples. Search Pirate4x4. Most of the guys there do not have that much money into their trucks, they just fabricate and use what's know to work. Most of the time, those $50K rig's are usually hacked together. It's not about money, it's about your know-how.
As for wheel spacers. There's a good picture on Pirate about why not to run wheel spacers. I can't find it right now, but I'll post it up when I do. Just figure it's not safe.
SAS it, 14BFF it. No more worrys about it being weak.
dizhai
