Condenser Suggestion
mnjeepmale
It's getting warmer here where I live and found out that my condenser is leaking where the receiver dryer is connected.
Some shops are quoting me anywhere from 1000 to 1400 for parts and labor. A lot of suppliers are running low on condensers as this seems to be common part that leaks.
I'm looking to buy a good quality condenser. What is suggested to buy?
2015 Tahoe LTZ 5.3
Sent from my SM-N950U using Tapatalk
Miami-Dade
Moderator Supporting Member
I don't have any extended warranty on the vehicle
Call GM Customer Service [866 522 9559] as they just might cover it. They covered mine about a month ago. Plead for mercy since this was a well known issue in the 2015-2017 models. Mine went belly up at 80K miles
I leave my a/c system constantly on so if there is a issue I will know it immediately. I just set it and forget it. I do that on every vehicle I own.
M
mnjeepmale
I'll try. I just bought the vehicle in February and declined any of the extended warranty when offered. Vehicle has 131K miles.
GMT800 2005 Tahoe Z71
Navy Supporting Member
Watch out, if you go back to the same dealer and you ask for help they may throw the extended warranty turn down back in your face. Just be prepared.
You may have to commit to the extended warranty before they give you any relief on the condenser problem.
If you have to pay try and find a recommended shop that hopefully will let you supply parts and save you some money.
M
mnjeepmale
I'm trying to find a shop that I can supply my own condenser. I see some supplier are out of stock.
My question, should I buy ACDelco? Im hesitant since the original failed
You can bet that since the condenser is a problem and they have been covering some of them, that the new ones are an updated better model. I would not hesitate to order one from Rock Auto, the link I sent you. The key is finding the shop that will allow you to supply the part.
When I looked up the condenser at RA I had the two choices to attach a link for. I chose just one. The one you came up with is out of stock. I guess it could be either. Depends on the options.
Post the last 8 of your VIN and hopefully @915_Tahoe will chime in.
M
mnjeepmale
Thanks.
FR151266
915_Tahoe
Your GM Parts Specialist
HELL PASO, TX
Currant GM#19383805 $182.02.
If your dealers in your area is out of stock, it's because these are on a national back order.
Where are you located at.
M
mnjeepmale
Twin Cities
So that's the one I want to buy GM#19383805
M
mnjeepmale
A dealer said this is the part # for the condenser after I gave them the VIN
Part # 84621302
Yes, and that is the same one I posted the link to. When I look now that is no longer showing at RA so who knows what happened to that.
M
mnjeepmale
Thanks for your help.
Looks like they are out of stock in many places. I will have to keep looking around for someone that has it in stock.
915_Tahoe
HELL PASO, TX
Here you go, hope this helps.
Northside Chevrolet
9400 SAN PEDRO AVE
1-800-727-8706
SAN ANTONIO, TX 78216-4497
Contact: Alamo Parts Dept.
Phone: (210) 341-2217
Has 44 in stock.
West Point Parts Center
11666 Katy Freeway
Houston, TX 77043
Contact: Doug Clement
Phone: (800) 364-6444
Has 31 in stock.
M
mnjeepmale
Northside Chevrolet
9400 SAN PEDRO AVE
1-800-727-8706
Has 44 in stock.
11666 Katy Freeway
Houston, TX 77043
Has 31 in stock.
Thanks.
Was informed there is another new part # replacing GM#19383805.
It's #84573456
Do you know?
Dh1280
