Complete Lighting/LED List
haks310
haks310
Got LEDs?
SoCal
So I purchase my other pair of these as I have finally figured out how to get them to work in our Hoes/Yuks:
http://www.youtube.com/watch?v=aLDmlT12UUA
Also have new TYC parking light housings to go along with them and a 55W 8000K HID kit to install in the headlights to replace the 35W 4300K one. Will post up pictures when I receive everything and install.
haks310
haks310
Got LEDs?
SoCal
haks310
haks310
Got LEDs?
SoCal
LoL yes indeed!
I will post up a video of the front once I install the new parking lamps, new HID kit and rewire the LEDs.
mikeykey
finally ordered my LED's!!!! should be on the way to finally finish my exterior/interior lighting.
BTW, the new parking lights from LMC are worth every penny. Don't waste your money on the cheap imitations I first bought from ebay.
haks310
haks310
Got LEDs?
SoCal
The LED parking lights? I thought you had picked up some TYCs?
haks310
haks310
Got LEDs?
SoCal
Kool, the IPCW ones right? LoL I had linked you tto hose in your parking lamp thread. Same route I was going to go but decided to go with the dual, color changing LED bulbs instead.
mikeykey
Yep...that's were I first saw them, through your link. I also am going to steal your idea for all white LED gauge lights with white needles. So that makes at least three things (including the lighted top reflector) I stole from you.
For a grown man, I sure do follow you around like a lil kid..............Great minds think alike
mikeykey
Got my LED's in the mail today and started putting them in. The corners look awesome, as do the interior ones.
Couple questions:
1. Is there a way to tell if all the LED's in the gauge cluster are on? These lights are so bright, I'm not sure they are all on.
2. I marked the gauge needles with a piece tape when i removed them. When doing so, I tried to pull them off in the exact same position but think i might have not got the speedo exact. Is there a way to put the gauges back on if you didn't have reference points.
3. What type of 211 dome light bulb would you guys recommend or have used. I'd like to use one of the multi-LED boards, but am not sure if it will fit.
http://www.v-leds.com/Interior-LED/Camper-RV-LED/White-LED/V-LEDS-HID-WHITE-48-M-p5217649-1-2.html
Thanks for any help guys...
p.s. i might have accidentally ordered too many of these: http://www.v-leds.com/Interior-LED/DomeMap-LED/White-LED/V-LEDS-HID-WHITE-6-LED-p5168709-1-2.html
If I can't find a use for them, i'd sell them to someone on here for a good deal.
---------- Post added at 04:21 AM ---------- Previous post was at 04:15 AM ----------
Also, if any one is looking at doing this project, I would HIGHLY recommend using these: http://www.v-leds.com/Exterior-LED/...LED/2-HID-WHITE-6-LED-LIGHT-p4481033-1-2.html in the door lights instead of these: http://www.v-leds.com/Interior-LED/DomeMap-LED/White-LED/V-LEDS-HID-WHITE-6-LED-p5168709-1-2.html
IMO, the panel ones don't disperse the light evenly through the housing, making it look kinda ******.
Also, I would recommend these for the corner lights, due to the multi-angle projection they put out. http://www.v-leds.com/Exterior-LED/...te-LED/2-HID-6K-WHITE-SMT-5-p4481039-1-2.html
Just my two cents
haks310
haks310
Got LEDs?
SoCal
Just make sure you don't have any dark spots. I put in two LEDs on different ends of the circuit board then made sure the polarity was correct, then worked my way in.
Once you take the needles off they will never be exact when you put them back on. Would be even harder trying to do it without a reference point. Tape was a good idea. Taking pictures of the gaugewith the engine off and with it at normal operating temp is also a tood idea.
Those circuit boards would be super broght. I am running the ones that have 6 SMT LEDs and they are plenty bright. I would give you the link but I am on my phone at the moment.
mikeykey
Well, i sanded my needles down today and then cleaned the up with acetone. While giving them a final "wipe off", two needles tips broke off. I guess the acetone makes the plastic brittle. Sooooo, its to the junk yard for some needles......
AtomicHoe094
Atomichoe094
cleveland, OH
whammeee that sucks man, sorry to hear about your needles, but while your there pick up some denali or escalade ones :)
mikeykey
Are they different.....I was wondering if the new ones would fit.....
qlc1964
qlc1964
hey!!! haks 310 what l.e.d did you use for the hvac i only have
3 in mine and does this small bulb comes out the holder?
the t 1.5 l.e.d is too big
haks310
haks310
Got LEDs?
SoCal
The T1.5s will fit. Sometimes the bulb and holder wont come out together so you will have to take the bulb out the holder and just replace the bulb. Superbrightleds sells the T1.5s bulbs by themselves, they're 74s
scottd
