Clunk noise not u joint
Familytahoe
2001 Chevy Tahoe 4 wheel drive. Truck started to make a clunking noise when shifting while driving when changing gears.. does not do it when I take off real slow.. slid under the truck and tried to wiggle the driveshaft around and there is no play so I do not suspect it is the U-joint and the transmission was changed less than 15K ago.
Any advice I have Sunday to look at it?
Scottydoggs
NJ
ive heard the torsion bar mounts can come loose.
CountryBoy19
Southern Indiana
Pull the bolts on driveshaft (after blocking so it doesn't roll) and see how much backlash is in your differential.That's what was causing my clunk.
F
Familytahoe
Update now it doesn't have reverse and in drive it takes forever to shift into gear
Scottydoggs
NJ
you check the trans fluid level? low fluid will cause this.
Ihaveatahoetoo
