Clunk noise not u joint
Familytahoe
2001 Chevy Tahoe 4 wheel drive. Truck started to make a clunking noise when shifting while driving when changing gears.. does not do it when I take off real slow.. slid under the truck and tried to wiggle the driveshaft around and there is no play so I do not suspect it is the U-joint and the transmission was changed less than 15K ago.
Any advice I have Sunday to look at it?
Scottydoggs
NJ
ive heard the torsion bar mounts can come loose.
CountryBoy19
Southern Indiana
Pull the bolts on driveshaft (after blocking so it doesn't roll) and see how much backlash is in your differential.That's what was causing my clunk.
SnowDrifter
Sasquatch Country
I have a small clunk when going between 2 and 3. 4l60e operation allows a slight reverse torque during this shift. That much is normal
Between other gears is not
F
Familytahoe
Update now it doesn't have reverse and in drive it takes forever to shift into gear
Scottydoggs
NJ
you check the trans fluid level? low fluid will cause this.
SnowDrifter
Sasquatch Country
At this point, I would advise you drop driving the vehicle. See if you can get a hold of a tech 2. Basically check for any trans codes, verify solenoid activation, etc. Anything you can get a hold of that would cause issue short of throwing in the towel and replacing a couple thousand dollar transmission
lkrasner
My slip yoke clunks loud as hell and always has for the record. Little less if I grease it up real good before sticking it back in. Only really heard when shifting from park into gear though, no noises on shifts.
Drewphil
