chevy tahoe tire pressure sensor
k1970
Oman
Hi,
It says the air in this tire ٢٠٢٠١٠٢٢_١٨١٨٤٦.jpg ٢٠٢٠١٠٢٢_١٨١٨٣٣.jpg is low. I put correct air in all tires, but it still appears all the time! What is the problem?
Ont240
Ontario
Add more air. Should be about 220 kpa cold.
Use a real gauge at the valve stem!
k1970
k1970
Oman
I think you are low, that's 27 psi on our side. Most of those take 35 psi (242 kilopascals). Do you play in the sand dunes over there?
I always put it at 33 all seasons! Is the corresct pressure 35?
I never played in the sand dunes! .. Ha ha ha!
PG01
Up here to the right
I checked all the tyres. The pressure is correct in all, 35.
On the driver door kick plate or b pillar there should be a placard with the correct tire pressure for the oem tire size and type. Disregard that. Minimum I would run is 33-35 adjusting up from there depending on tire wear and feel of the vehicle.
as for the light on the dash. A sensor isnt reading correctly or something like that. First thing I would try, with truck running or at least key on engine off, 1 tire at a time drop pressure to 15-20 psi starting at passenger side front then refill to at least 35 psi, then move to passenger rear do the same, drop and refill then drivers rear, drop refill, finally do driver front drop and refill. Try to do this quickly, no breaks inbetween tires. See where this gets you.
