Cheap ebay LED bumper lights..
Tahoewhat
Ballin' on a Budget
TX
the inner ones, the DRLS? and downward ones? Lost me there... but sounds like bad connections... If they go off and on...keep us informed, b/c im fixing to buy some for a friends bday gift. (was going w/ the motorblvd) b/c of previous.
Kyleg234
Kyleg234
Champaign, Illinois
I got both of my lights working flawlessly now.. and i got the 70$ ones so i guess the more expensive isn't always better..
Tahoewhat
Ballin' on a Budget
TX
yeah, i dont think it really matters how much you spend. All of them are basically made from the same Taiwan place, distributed to diff. companies and sold to us. Some are good some arent. All part of buying something made in very mass quantities. Glad yours work now.
bigrhino
l.e.s manhattan,nyc
I purchased those some lights earlier this year and they work great only problem is with this heat and humidity i have a real bad condensation problem. i must of poured out about a half a cup of water between the two of them. Any suggestions on solving this problem. Thanks.
Tahoewhat
Ballin' on a Budget
TX
Silicone them. I had the same issue, here in houston. But goes away.. Just silicone the part that plugs into the light and you should be good. I did and has been fine since. Basically get a good seal around the plug
Dismay
Minneapolis
Yeah, each forward main led has one that is underneath it that faces downward toward the reflector. since three of the main leds are not coming on, it means there is a problem with the inner circuit board or connections/solder points, which would require opening the housing to get at them. not sure if this is possible, didn't want to try pulling it apart. The intermittent wire connection is also at an internal point, the connections at the plugs seem to be fine.
MotorBlvd got back to me, I gave them a deposit to ship out a new pass side light, and then I'll ship them back the defective one for a refund on the deposit, that way I can at least keep them in the veh for now, and also keep the working driver side one, rather than ship the pair back and chance getting a defective one on the other side.
Basecamp
