Changing Plugs and Wires
Sdp1234
Southeastern PA
I don’t have records for my Yukon Denali 6.0 2004. It 170k Should I change the plugs and wires? No perceived problems but I wondered if it was prudent to do it since I don’t know their condition. If so, what plugs and wires are best? Thanks
wjburken
Eastern Iowa
Change them.
Let’s assume the previous owner did change plugs. They probably did so around 100K. That would put 70K on your plugs and a good time to change them. Now let’s assume they didn’t. It’s definitely time to change them.
I prefer AC Delco myself but others on here have tried NSK with decent luck.
https://www.tahoeyukonforum.com/threads/best-ignition-system-for-my-2004-tahoe.115343/#post-1389718
https://www.tahoeyukonforum.com/threads/170k-on-factory-plugs.115337/
rockola1971
Indiana (formerly IL)
I had to do mine on my 05 Yukon Denali because the misfires were getting horrible. The engine has over 315k and I swear the plugs and wires looked to be original. The spark plugs electrode was gone...as in no there! The wires were dry rotted and just fell apart when I removed them. Runs much better now. Have fun with the passenger rear cylinder. Its fun trying to get the old wires off and new ones on. Getting to the stupid plugs is a blast too.
OR VietVet
GMT800 2005 Tahoe Z71
Navy Supporting Member
Willamette Valley
What Wade and Mike said but you could pull an easy one and post a pic here, close up, so we can see what they look like. Plus, if you do change them it is a perfect time to see if there is any oil or misfire or fuel delivery problems in any given cylinder. If you pull them all, replace them all and do the wires. AC Delco parts is what came in it, I would stick with them.
2010gmcyukon
Midwest
I agree with what the others said; change em out. You should be able to get AC Delco plugs and wires pretty reasonable, just shop around a little. I found a decent price at rock auto on mine.
joexyz98
Change them.
but then again if its not broken dont fix it sorta in same situation 03 yukon had it 8 years over 100 thousand miles not missing a beat no rough idle no engine knock , no misfiring
drummin1
I know on my 2015 Yukon Denali it was recommended at 100K, I did it even though there were no issues. I think it's just a good, high miles thing to do.
wjburken
Eastern Iowa
It’s all about personal preference with when you want to address a problem, address it before it happens or address it after it happens. I am firm believer in Preventative/Predictive Maintenance not Reactive Maintenance. Having spent the last 20+ years designing and building things ranging from semi-trailers to truck mounted snow/ice control equipment to Non-Destructive test equipment and now high speed automated packaging equipment, it is a proven fact that intelligent preventative/predictive maintenance saves money and prolongs the life of equipment. I apply this same principle to the vehicles that I drive. I, personally, am amazed that folks will hesitate to invest $100 or so to replace plugs and wires on their vehicle once every 100K miles.
If you are good with stretching every last mile you can out of a set of plugs and only change them after you are starting to have problems, then you do you. You know a lot more about the history of your vehicle than the OP does about his, which is why he was asking.
OR VietVet
Willamette Valley
AS my dad told me once, "Maintenance pays and Breakdowns cost". Always better to do the recommended maintenance when you know what the cost is and when it will be done. Breakdowns leave uncertainty and typically cost more and stretch out the time when it will be done.
rockola1971
With wires its more age. Plugs definitely change. Parts are cheap, maybe 200 for AC Delco. Will perform better.
Theres no need to blow $200 for AC Delco parts for the spark plugs and wires. Can be done easily for less than $60 with decent quality parts that will last.
Wylie_Tahoe
My new to me 03 has 285'ish and runs fine, but plugs and wires are on the list to do, since I do not know the history.
The time to "check" the plugs, is the same to change them. only the cost of the parts.
Nothing worse then trying to check the plugs, and having a couple wires tear apart on you. Now you have to get another ride to auto parts store to get a set of wires you did not have plans to change.
get a set of wires and plugs and just change them.
avalonandl
Troy, MICH & Naples, FL
Rockola: I disagree -AC Delco wires are about 60 a set. Plugs are AC Iridium and you WANT AC Delco or NGK... Any set of good wires and Iridium plugs and is going to run 150-200 total.
Some of the stuf on Ebay and Amazon thats cheap are counterfeit plugs.
Wylie_Tahoe
Just ordered mine. AC Delco wires are > $60 and platinum plugs are > $3 ea. So inside of $80 for standard wires and plugs. The NGK Iridium are $5.25 ea, so inside of a $100 for wires and Iridium plugs.
glazar
