Erickk120
- Joined
- Mar 19, 2018
- Posts
- 384
- Reaction score
- 213
Yes, then you can do the hacksaw trick cut it and it comes out after a few taps, the trick is to not heat it til it melts, just get it hot enough and the rubber should separate from the metal all around it and then tap the rubber out.Trouble is it still leaves the metal casing around thr bushing :/
Sent from my SM-G925V using Tapatalk
