Cam Swap
2005SnowKon
Fort Collins, CO
Im wanting to do a cam swap in my 05 Yukon 5.3 here in a few months but not sure what to go with. Already got a CAI, exhaust and a custom tune done to it. What would you guys recommend doing? anything else i need to do when doing this swap?
ezdaar
Chat Troll
Redneck central, Aka Houston
springs are a MUST! and Pushrods are highly recommended
This is what 90% of all ppl replace when doing a cam swap, some is required others are simply because "I am in it this deep, might aswell"
Pushrods, Hardend, OEM is soft weak metal that bends, save sme cash hit up LS1truck, LS1tech and performancetrucks.net, buy a used set of TSP (texas speed) at the proper length, ask your cam builder, DONT buy a pos over the cointer cam.
Valve springs, If your cam requires a min of .600 lift, but .630 lift springs (insurance)
Retainers and caps, Titanium for lighter valve train, increased power and reliability
Valve seals, Viton
Lifters and lifter trays <~~~~~ LS7 stocks are cheap and dont tick, But have QC issues as some dont properly fir the lifter bores. Spend the cash and go COMP.
Timing chain
Oil pump, High volume / High flow, aka port the OEM pump
All associated gaskets with the BEST you can afford.
Valve spring removal tool, LS1truck and Tech has these as they are custom made by members.
Rocker trunion upgrade, stock rockers will fail with big or extreme duty cams causing engine failure
NO MATTER what cam you install you MUST change out the valve springs! DONOT listen to anyone telling you otherwise!!
OEM springs are on the verge of being to small as it is.
Go bigger cam on stock springs and you float a valve, bind the coils and Blow that motor..
Hit Texas speed, Summit racing and Engine performance systems, for complete to end packages. they come with everything you will need.
I reccomend TSP or EPS as they are Texas boys and will bend over backwards to make sure you get exactly what you need.
GL
hoe
Call TSP. They recommended one similar to the 228R for my 6.0. Good guys to work with.
Yea, but he has a 5.3 with not much at all done to it except a CAI and a muffler. I cant picture him needing nothing more than a 212/218 on a 114-5 lsa
IMO im not no cam expert, just what I would judge from his sig.
ZaZaZazzels
