Broke clip on headlight bulb connector (2017 Denali)
PivotalRex
I was trying to upgrade my hid bulb to vanquish auto 6k bulbs and broke the clip on the connector that plugs into the bulb. Oem bulb works for now but figure its just a matter of time before it loosens free. I did a search for the part, havent come up with anything. Figure its part of wire harness that connects to ballast so this might be pricey to have replaced (labor wise).
Has anyone else broken this piece? It's the little gray clip on the plug.
dbbd1
Nope, I have not broken one. Bet you were out in the cold doing it? Dang plastics gets brittle.
Sounds like you will need to order a new plug assembly (from Amazon?) for your headlight and wire it in. High or low beam?
I would solder it too. To get a real good connection. Then seal it well with tape or that "liquid" electrical tape.
P
PivotalRex
You're right about the cold, I barely touched the clip. Gave up at that point. Found a couple oem ballast assemblies on ebay that have the connector but its 90 bucks and for driver's side, not passenger. I'll check with dealer tomorrow and see if I can just order the connector from the bulb to the ballast.
dbbd1
I would try Dorman or Amazon first. Nooooooooo, not the dealer!
High or low beam?
when you get the new one you can push the tabs in on the inside and pull it out and swap them out, I wouldn't splice it, just takes a metal poker tool somewhat like a ice pick.
dbbd1
Cool! I should have thought of that!
TallHoe 96 OBS
