Brakes
plush
Thinking of getting these, as the BBK is out of price range. Why the difference in size from front to back? Also, would you not think the larger ones would cost more?
EBC Sport Rotors
FRONT - 13" Rotors - $269
REAR - 13.6" Rotors - $253
EBC Yellow Stuff Brake Pads - $98 * 2 = $196
Could you not just put 13.6 all around?
Anyone else have these and thoughts?
KMeloney
The fronts do the majority of the stopping work, so it's probably a pretty different front set up making it more expensive than the rear. As for the size diff, I don't know.
Zed 71
Pacific NW
The front rotors should be larger so check the specs above.
As Kirk mentioned, the front rotors do most of the work so they are smaller. If you put larger rotors on the rear (fronts the same), the ABS would probably kick in more often because the brake bias is not balanced.
plush
plush
TallHoe 96 OBS
