Brake issues post cam swap
RET423
I don't think the light is related to the pulsing, the light is likely a wheel speed sensor or the brain on the ABS unit failing but your pulsing is likely poor vacuum after the cam swap
A good tune can restore some of the vacuum at idle, with your cam it should be possible but I would research how to tune for idle vacuum if your doing it yourself & see if you can get rid of the pulsing that way
Good luck!
BlackedOutHoe
BlackedOutHoe
Low & Slow
S. Carolina
Good luck!
Seems to be the general consensus. Hoping to get a retune and I will report back. Thanks all!
jkhuntzinger
