Brake fluid leak
blue99tahoe24
bout that tahoe life
joliet il
What's up guy was fixing on the Tahoe did ball joints and hub bearing on passenger side got everything put back together feeling pretty good I get to drive my truck and I start it up and pump the brakes and brake fluid Is dripping from the lower control arm I can't seen to find where it's comming from if anyone had this problem or can lead me in the direction thanks
Sent from my C6606 using Tapatalk 2
SunlitComet
OBS Jedi-Do Good
unknown at this time.
Try looking at the joint where the rigid line meets the hose. It could be seeping the control arm and running down to the end perhaps.
blue99tahoe24
blue99tahoe24
joliet il
Problem solved coolant leak from Heater control valve this is gonna be the 3rd one I changed idk what the problem is
95escahoe
That's a pretty common issue, shouldn't go that quick replaced mine 3 years ago and it's still good
Sent from my HTC One X using Tapatalk 2
blue99tahoe24
blue99tahoe24
joliet il
Lol yea yea I kno should have investegated more:D
Sent from my SGH-T959V using Tapatalk 2
